I was able to open my Seiko Solar watch which has been lying dead and dormant for about 3 years (huzzah), and removed the suspected problem, the dead battery. I'm looking around the internet for a replacement battery and I can find them, but they don't have the proper clips on them, or even no clips at all. What do I do?
Hi welcome to the forum  First thing is we need to know the caliber of the watch.  Look under the No 6 position on the dial there is a number can you post that and a photo of the movement  and any caliber numbers of the back plate, Once we know what it is we can point you in the right direction               cheers
On the face under the  6 position it reads: v157-day8 hr 2
The movement reads:
Seiko Time Corp.
2
Japan
V157A
Two Jewels
I was able to deduce that I need a Panasonic MT920 battery, but I just cant figure out the mounting clips issue. I can find the battery naked, but those clips elude me.
Additional update: I may have found the proper battery with the proper clips, but I am interested to see if anybody has other solutions regarding it. If it's cheaper to buy a naked battery and attach clips (if that's possible) then I am all ears. Being new I want to hear as many opinions as possible.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
