Working on a Jules Jurgensen 5899C , can anyone help in informing how to remove the stem off this one.
Photo of the back of the watch are attached
Thanks in advance
Hi   I notice there is a caliber number on the plate near the jurgensen name, I suspect this is a Hattori/seiko/Epson rebadged movement as there is made in japan on the plate can you identify any other makers marks on the movement at all    reason for asking  is to try and find a tech sheet for more information
When you pressed the post did it move at all as that is the most likely one.  can you also photograph the the full movement     thank you
hi    It is concievable that it is stuck for whatever reason,  try a drop of penetrating oil around its circumference and let it soak in before trying again.
