Cleaning Inside Of Mineral Glass
ro63rto
I noticed a sort of fogging on the inside while playing with my LED torch, charging up the lume on 3 of my watches, Sector 155, Breil Ducati One and Seiko Arctura.
I have 100% Acetone, Switch cleaner and plasma tv cleaning fluid.
Are any of these ok to use on a q-tip?
If not, anything else I should get?
I would try using a weak solution of washing up liquid with your q-tip first. It should remove it and there is no chance of melting something in the process. I certainly wouldn't use acetone ar switch cleaner, the plasma tv cleaner would probably be OK.
Hi ro63rto,
Whenever using a q-tip be careful with the lint it leaves behind. I clean my crystals with Windex but never "spray" directly. The lint free paper and the blower -- even sometimes a dial brush to pick up the lint -- assure a lint free result. Also mind humidity and rubbing if there is a chapter ring held in place between the crystal and the case. Sometimes it can get cracked, discolored and otherwise damaged. The humidity left behind by the cleaner may fog the watch after closing it. Also if there is any spot where the q-tip catches on parts, it could dislodge them and/or damage them...this is mostly seen when used in dials which is not your case....but I like to be thorough. :)
During cleaning I tilt the crystal to different positions, observing it through the light. Mind that some Seiko crystals have a coating on the inside that should not be touched according to them, only the outside.
Cheers,
Bob
i may be missing something but fogging on the inside of the case would indicate that the watch is not sealed? - like i said, sorry if ive completely missed the original question.
You are right in asking but this fogging is unlike anything I've seen. Normally on a non sealed watch I start to see a circular foggy patch in the middle of the crystal.
These look like someone has wiped the entire underside of the crystal with a sweaty finger.
....it could be a lot of humidity or water might have actually gotten in (hot showers are the worst, etc)...is it actually wet?
There is the dust and the fogging due to age, expired seals, etc. So far, the recipe given was to clean the crystal...
For humidity you still need to clean the crystal but a good service and detection/fix of the unsealed spots is necessary...normally replacing o-rings, gaskets, silicon grease, etc will fix the problem...at least that's what I do. Pitted and rusted joints may require more work or impossible to seal completely...
Opinions/how-to's are appreciated to help improve!
I can safely say I have never worn any of my watches even while washing my hands let alone in the shower or while swimming.
I did notice that the Breil has what looks like ice crystals. Have to use a louoe to see it.
I will check closely for moisture signs when I open them up and remove the movements though.
Fogging on the inside of the lens is no good . Could be a bad gasket or you have pressed a button on the watch when it was wet .
When i assemble  a watch the last thing do is use a camera lens cleaner . I buy them on Ebay . You could buy them on Cousinsuk . They are much cheaper to buy a dozen from China . It has a little sticky round cleaning tip in one end and a brush in the other . http://www.ebay.com/itm/3-in-1-Kit-Lens-Cleaner-Pen-Dust-Cleaner-For-DSLR-VCR-DC-Camera-Nikon-tool-FO-/291317706237?pt=LH_DefaultDomain_2&hash=item43d3e36dfd
That looks quite useful.
I have the usual blow brush in my camera kit but it doesnt have that other bit.
Thanks.
Thanks.
Inexpensive but do the job nice . Hold up for a lot of watches and it has two sticky sides in one end of the pen . Remember to throw it in the plastic recycling basket after it has been used up .
    • My favorite is my first mechanical watch.  I received it as a present when I worked in Japan about 20 years ago (don't remember the exact year but it was between 2004 and 2006). It is a Seiko SAGN011 with the 4S27 movement and a titanium bracelet.  I unfortunately dropped it in a way that made it stop working.  I sent it to Seiko US for repair, they sent it to Japan without looking at it and the service and repair ended up costing $610 By the way one link in the bracelet is damaged and needs replacement and I have no idea how to find one.  If any of you know how it can be done it will avoid another expensive repair, right now my wife has a trip to Japan planned for the fall and we are thinking about having it repaired then. It is exactly like this one https://wholesaleshop.ru/product/134848968779
    • Yeah I have the cheap one.  But I think you are correct and they are reversible I hadn't tried turning them other but I see it in the picture (I am at work can't check the actual holders right now). I'll probably get better one at some point but right now there has been a lot of tools to buy to start so I am cheaping out on some things.  I am quite happy that I did get a microscope because working with a loupe was just not working for me at all. next big stuff coming is ultrasonic machine, cleaning solution (99.9% IPA and Naphta) and lubricant (Moebius 8000 and Molikote DX for now).
    • I’ll be getting into them sometime this year, my grandfather’s pocket watch was one of the reasons I got into this rabbit hole. Funny enough last week whilst I was replacing a couple of batteries for the missus she done the old “I just remembered something “ and wandered off. A couple of minutes later she hand me her father’s and grandfather’s pocket watches. Apparently she got them from her brother years ag because I was into watches and thought I might like them. Not looking forward to looking at her grandmothers watch, solid gold and the head is pretty much the size of my little finger nail.   Tom
    • Hi Murks, I would just measure the old spring and order a generic one closest I can to size. Especially on thickness and height, length doesn’t matter so much as long as the difference isn’t huge.   Tom
    • As it’s Seiko have you tried a search in cousinsuk crystal section using the case reference?   Tom Had a Quick Look, 310W13GN00 looks like the part number you need but every listing I have found is a discontinued line. You might want to measure up the one you have and look through the sternkruetz catalog, here is a download link http://www.sternkreuz.de/accordion/assets/Sternkreuz_Gesamtkatalog G22.pdf   Tom
