Pallet fallen out
Hi I am trying to get an old russian vostok clock working. The escapement was not engaging and the clock just free wheeled until the spring ran out of energy. When I disassembled it the pallets were rotated 45 an 60  degrees up from the plane of the gear. I was able to return one to true but the other popped out. Just had a frustrating hour trying to replace the pallet. Is there a trick or is it a fools errand??? They seem to be  a push fit
The pallet stone needs to be re-seated. You need to clean the stone of everything that is on it, this includes the part of the pallets that the stone fits in. This is not a job for someone that has little or no experience. Watch/clockmakers shellac should be used to set the stone. It has to be the correct angle, this includes depth and height. Do not use any of the quick hardening glues that are available as they act so fast you will not be able to adjust the stone. If you intend to undertake this work I can list the tools you will need.
Thanks guys. I think that means the job is beyond me. I'm sure after much swearing I could get it randomly sited but couldn't hope to achieve the precision required. Is there any resource to buy a new part. There is a whole new escapement on ebay for $70
With this platform you need to find out if it will fit to engage the teeth of the wheel see photo and arrow, this part must be clear from the wheel it is to engage, you also need to find the leaf count, in other words it must have the same amount of teeth as the original.
    • It looks similar to some AS movements, but it's not identical to any I can find. There may be a logo / number under the balance wheel??
    • Many would disagree: https://www.rohm.com/products/faq-search/faqId/234 https://uk.farnell.com/c/semiconductors-discretes/transistors/bipolar-transistors/pre-biased-digital-bipolar-transistors https://uk.rs-online.com/web/p/bipolar-transistors/8232832P?gb=s https://uk.rs-online.com/web/p/bipolar-transistors/0580240?gb=s (RS don't have a specific category, but over 1000 "digital transistor" items).
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
