Hi guys,
I wonder if anyone can help me? I've been given a Cartier Tank Americaine chronograph 2312, with a 212P quartz movement inside
The hands won't set because the operating cam is missing
The winding stem passes through it and when the winding stem is turn slightly, the minute and hour hands will move. How much depends if the winding stem is pulled out into the first or second position.
I've taken a picture of where the operating cam should go and have marked it with red. I also have an operating manual by Cartier, which is pretty scant on any real information that is useful
So what I would like to know is, what is the job of the operating cam? I'm assuming it makes a contact between two points
Also, does anyone know where I can get a replacement, otherwise I'll have to make one out of 0.5 mm thick brass and put a 0.8 mm square hole into it before filing it down to shape? The winding stem is 0.7 mm wide where it passes through the operating cam.
Does anyone have a better schematic of this movement, other than this I've attached?
Cartier_212P-TECH.pdf
I was forced to make an operating cam, which was a 3 hour job with a piece of 0.4 mm brass. It had to get honed down to 0.2 mm to fit in the slot.
Total dimensions were 1.2 x 1.2 x 0.2 mm, with a 0.7 mm square hole passing through it to accommodate the winding stem.
The last picture is with the operating cam in place. Damn fiddly work, but very gratifying seeing it work. Lord knows how much Cartier would have charged me!
Not easy to find parts to those  Cartier (Piaget) 212P movements.
Nice job filing that part, guess it is what it comes to with these ones.
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
    • To get the full diameter, I'd have to take it out of the case, which I won't be able to do until the screwdrivers arrive.  I doubt that it's much use to you, but the raised rim on the case, encircling what you see of the movement, has an outer diamter of 28 mm and an inner diameter of 24.8 mm. The case outer diameter is 32 mm.
