Seiko 7019A case back cracked
Hello!
I hope my message will find everyone of you in good health.
I'm actually working on a vintage Seiko and the case back is cracked (see the pictures).
Do you have any idea/solution to repair it or it has to be replaced?
Thank you and have a nice week-end.
Nico
