Im working on this vintage 11ALACD. The diagram for the automatic mechanism is below. Do I oil the interface of the reverser wheels circled below? I read somewhere that I should treat the reverser wheels with epilame but I am not sure that applies here.
Yes.
Next question is what sort of oil to use.
There are a couple of Bulova service manuals around for similar watches. The first one also gives some information on checking the tension spring, but neither tell you what oil to use.
https://www.buzzufy.com/ebooks/11AOACDB.pdf
http://www.phfactor.net/wtf/Bulova and Caravelle/Bulova 11ANAC, D, B.pdf
This shows what happens if you don’t oil them
https://onatelier.co.uk/bulova-automatic-divers-watch-666-feet-m7-calibre-11alac-service#more-2183
Let me know how you get on. I have one of these in my project box waiting attention.
I would lubricate with a tiny bit of Moebius 9501. I am sure others will have other preferred lubricants but thats what I would use.
Seems my options for this application are KT22 grease or 9104 in my possession. Would you guys say one is better?
Also I already treated the reverser wheels with epilame. Doesn’t that mean the oil won’t spread over the teeth?
Edited by patchwerk
