14 minutes ago, SorenHartmann said:
I am about to paint my dial on my diving watch and want to use a strong glowing luminous paint?
Just curious, have you ever produced a dial before? How are you going to paint it, airbrush or perhaps traditional brush with a artist touch? What about the indexes, will you detach and then reapply these small fiddly thingies? Not to mention, having some sort of logo is often desirable, how do you plan to do that?
No matter how you will solve these  small issues or the choice of the paint with the greatest albedo, I look forward to to see the results of you work, good luck!
Thank you for your replies
No, I have not produce a dial before, so I will have a back up dial, just in case it goes wrong.
The logo I will download and add to the label together with the digits and the transfer to the dial. As per video: How to print a custom watch dial - watch building tutorial
The intended plan is as follows
  • Sand the dial to make it smooth
  • Mix LIT (luminous powder) with the acrylic base to make a paint
  • Apply the luminous paint all over the dial in thin layers several times
  • Apply the digits etc, by using the technic describe in the video below
Let me hear your thourghts
Thanks
Soren
I heartily recommend that you repeatedly practice all the steps involved on something of no  value, until you're confident with the skills and results achieved.
The idea then is for the  whole dial to glow. And for the hands and the dial not too? Do you intend to use non luminous  hands? I think that usual  luminous  dive watch hands could be a problem  to see.
Might  it not be better to have non illuminated hands so they would be in contrast to the dial  and therefore more visible?
Any idea how long the paint remains stable i.e its luminescence, It would be sad to spend all that time and find out after a couple of months it fails to glow
    • Heh. Well, also I just want to be able to do it, for no other reason than it's interesting. Same reason I restore antique tube radios and ancient computers- like, from the 1970s.  Sometimes, the parts just aren't there and you have to know how to make them. Learning how is a challenge and can take months or years, but it's honestly the best part! You can't beat that sense of triumph when you do something that's really hard to learn to do and do it well.
