Hi we will need clear pictures of the rear of the movement  in order to see which release mechanism it has. They all differ some require pressing a stud, others pressing a small lever only visible when the stem in in the hand set position. so without the pictures we would be guessing.      This is a solar powered watch.  with a capacitor to drive the circuit block.
Remove stem from a 8c23 Seiko quartz watch  were to depress cant find help
 I BELIEVE ITS A 6309
AS YOU STATED need picture of watch I have it THANKS   REPLY
On 2/25/2020 at 3:01 PM, 1937 said:
How to remove stem  from Seiko 8c23-6059 I believe stem=354 351
back of watch reads 8c23-6059   564384   were to depress
That small image doesn't help much but the release end of the setting lever should appear with the correct crown position, in the round hole right of the stem, I can faintly see an arrow marking there. For your reference attached the service document.
8C22A_8C23A.pdf
you say the round hole right of the stem, another FORM says its the square hole push
WHICH IS IT?? DOES ANY ONE NO  FOR SURE I CANT SEEM TO GET IT OUT -- REPLY THANK'S
Answered above already, but you should post a better resolution picture.
