HI,I am not sure where i should post this question, if at all,but a friend of mine asked if i could clean up his Casio Edifice EF -101 and i duly obliged.it needed a new crystal.no problem.then it came to the bracelet.Casio no longer supply this model and the lugs are narrow (12mm) and the end pieces were some sort of plastic. i have hunted everywhere for replacements without any luck.any ideas how to fix this without too much expense? grateful for any suggestions (within reason:wub:)
As said above one possibility could be 3D printing but expect to pay at very least the cost of a new same watch. Maybe you can fix the end links with epoxy glue, sand excess material and paint.
i dont think its worth the bother.might try bits from other bracelets!
