Replacing Glass In Rolex 1675
Well then there are these:
https://www.cousinsuk.com/product/watch-bezel-fitting-die-set?code=B30545
Or you could seek out a local engineering company that might be willing to cut one down for you in their lathe, or any local clock workshop should have one, they may help you.
These are pretty good value Mark, thanks for the heads up! :-)
Maybe I can find someone with a lathe. Which diameter die did you modify?
I modified four different sizes as this is for other Rolex models too then I painted a green band around them so I could easily identify them in the box of dies I have. If you measure the outside diameter of the glass you are fitting and choose the die accordingly you will be fine. And, naturally, the depth needs to be at least the height of the glass.
Thank you guys, here's the odissey I went through to get this job done: The watch came originally with a plain glass, (no magnifier) so I tried to track down a correct one with the magnifier (ref 714AWD) I first got one on ebay for 43$ shipped. After some time I decided to take the watch to a watchmaker to install it, probably the glass was ruined by using the kind of press in the picture and applying too much pressure, at first it was even inserted unevenly, it was taller on one side. Anyway the glass developed some kind of tiny cracks inside. I tried to polish it but it was not good anymore.
So I tracked down a new glass and this time I found one on ebay for 19,99$, took it to another watchmaker, this guy managed to crack the new one and reinsert the old one, he also told me that the one that cracked was the old one, that he cracked it while removing, infact he cracked the new one, I am sure as the old one had a tiny sign on the inside and it was still there. Then I got fed up about these people, tracked a new one which this time I paid 33,95$, bought some tools and replaced it by myself. I used a budget screw type press.
Hi chriz,
That is my first press, does the job but it is wobbly and not very even. All that said, it has been my workhorse for quite sometimes. Now I got better ones and I can tell it makes a lot of a difference...no more cracked crystals and better/faster performance.
I'm glad you were able to fix the watch. Good job!
Cheers,
Bob
    • Hi Bob, Welcome to the forum and thank you for your service.  I would never try to discourage you from getting into this wonderful hobby/profession, but please be aware, it does not cost just a few dollars to get into watch repair.  Tools are expensive and in many instances the cheap knockoffs are worthless, especially when learning.  You can get the tools needed to disassemble, clean, inspect, reassemble and lubricate a watch without spending thousands, but as soon as you start getting into task-specific tools, there are so many and they don’t come cheap.  My suggestion is to start with the basics required to disassemble, clean, inspect, reassemble and lubricate only, and build upon that gradually as the need for other tools arises.  The advice above regarding starting out on working movements is gold. Many of the non-running watches on eBay have been bought, tinkered with, deemed too difficult and then sold again, often with more damage done each time.  Without experience, you clean and service a non-runner and it still doesn’t run. What now? Troubleshooting is difficult as a beginner. This can become very frustrating.  I would encourage you to buy a working movement, and learn to strip and service it. If it isn’t running afterwards, you know it’s down to you, and as long as you didn’t damage anything you know that the parts you’ve got can form a ticking watch. An excellent movement to start with is the ETA 6497 clones from China, such as the ST36. They’re not expensive, and although it finds use in some larger wristwatches, this movement was originally designed for use in pocket watches, so everything is larger and easier to see and handle.  Once you can service a new ST36 and have it running better than it did when it arrived, you’re definitely ready to step up to working vintage watches and then think about repair of non running or poorly running watches.  As far as cleaning solutions go, you will not do better than the commercial watch cleaning and rinsing solutions that are available. You’ll find plenty of suggestions for home brew cleaners online, but the professional products are superior and you want to give yourself every advantage you can, especially when you start working on vintage movements containing hardened decomposed lubricants and often years worth of other dirt and dust. Alcohol is ok for cleaning or rinsing movement parts that don’t contain any shellac. The pallet fork and roller table contain jewels secured with shellac and will tolerate a rinse in alcohol but not prolonged exposure. Methanol dissolves shellac faster than ethanol, and isopropyl alcohol dissolves shellac slower than ethanol. Just in case you don’t know already, the radium on the dial (and likely the hands) of your Dad’s Elgin is highly radioactive. It is safe enough when safely contained within the watch case, but the moment you open the watch and especially when handling the dial or hands you must take precautions against inhaling or ingesting any radium.  Best Regards, Mark
    • I have both sets and use the K&D 99% of the time.  Yes, you have to be careful with the pin.  I use a screwdriver to carefully release the pin from the spring.  Some skill is involved.   I have also modified/replaced the pins in the arbors as necessary.  Yeah, you would think a tool would not require modification, but such is the world of watchmaking.  There is no perfect tool.  Each watchmaker must the tools to his skill, or vice versa.
    • I have the 8-11mm K&D but it doesn't do a great job with modern mainsprings, or I have had terrible luck. The arbor pin protrudes too much and I have damaged more springs trying to disengage the arbor than I have successfully wound and inserted. It seems easier to use with old carbon steel springs. My Watchctaft set gets far more use, though I have to get creative to wind left hand springs
    • It depends on what the gaskets are made from but silicone lubricant should work.  Spray or rub on a generous amount, put in a sealed bag and wait a couple of days.  Test for softness and wipe off the excess.
    • For hardened gaskets, an experienced watchmaker told me he usually found heat to be the best to soften them up. I tried that on a '70's Tissot where the gasket had turned to essentially epoxy to no avail, but eventually got it off with a 5700 case back opener using a crowbar for leverage to turn the wheel.
