Hi there, I'm Mudos and I'm from the Netherlands (Holland). I'm completely new to watch repair and I would like to learn some of the basics of watch repair on this forum.
Thank you and have a nice day :)
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
    • Probably more than you need to know in these two vids, but sharing because I found them quite interesting. 🙂
    • And then the problem of the stud holder and regulator which are on the wrong sides of each other:   I am baffled as to how this will have happened?  They can't re rotated into place, the regulator pins stop the spring stud from moving past. I don't think I can remove the regulator and/or spring stud without a staking set?
    • Just to inform that this is not a shock protection, just end stone fixed in place by the spring.
    • I had the privilege to be put on secondment to RR Ansty just outside Coventry to help design and build a power station at the old Fort Dunlop site in Birmingham. The sound of those Trent engines when they fire up is something to behold.
