Russian manual wind.
I picked this little Russian up and was enamored by the dial. When it arrived I discovered it had the stout Vostok 2209 movement. I found it was a very clean movement and only needed to be adjust for timing just a bit. The dial that had my attention looked to be silver plated copper with a rather dirty looking patina. The dial isn't engraved as I had hoped, but was stamped with the pattern formed during that process. I wanted to make that pattern pop so I painted the entire dial flat black and used thinner to remove paint only from the top surfaces. Was a bit tricky to accomplish but I think it came out great. Next I turned my attention to the hands. Somene had put a shiny black varnish on the hands as contrast, no lume was present. So I cleaned that of and since I didn't have any white paint, I used liquid white out. I know this is probably blasphemous, but it's a totally temporary solution until I get some lume I like. Placing the hands back on was a bit tricky as the fit was incredibly tight and tough to accomplish with my  huge sausage fingers. I have a black leather strap on order for it. Very pleased with the results. Thank you for reading this.
Edited by FLwatchguy73
  • Like 7
