Hello
I can imagine that I have to tilt the movement including inner stem into the case, after pushing the outer stem and crown into case. But I can´t "hook" the inner stem to the outer stem, even if they seem to be in corect lengths.
Kind regards
Edited by Khan
Sorry, it's difficult to understand you. What exactly you can't manage to do, and why? Please refer to stem sections as inner and outer.
Hi Jdm
I have now reformulated my first post. Let me know if it makes sense. Thank You.
I understand. The two parts are supposed to hook by pushing firmly when aligned. You could try this with the mov't out of the case.
However, I had the same problem, it seemed to me that the force needed was excessive, and I didn't want to risk breaking anything. So what I did was to remove the crown, join the stem and insert mov't in case.  Then applied locking agent and screw in the crown. It could not be really tightened it, but in my case it's a watch which not being used.
Do You mean, that I should put inner and outer stem in level and push horizontally? Because It doesnt get in level if I try to tilt as in shape of a roller coaster movement.
Not sure what a roller coaster movement is but the two parts definitely will have to be level to snap in. If the outer portion has been cut too short the crown will touch the case before they do.
With the movement out of the case I would first check that the stem pieces do actually clip together correctly.
This might be easier by removing the female part of the stem from the movement and holding it in a vice whilst you then apply the male part of the stem with crown. Do they clip together as expected?
Yes? Now put the female part of the stem back in the movement; check it is properly  engaged / secured before proceeding.
Now place the movement in the case. Look along the case tube ... is the stem nice and central? Put the case flat on your workbench and try engaging the male part of the stem with crown. You must push evenly along the axis of the stem; do not push at an angle. What happens?
Hello Watchmaker
It worked! I really appreciate your time in describing it step by step as easy as possible.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
