Reversed regulator
Buffo
G'Day,
I'm in the process of getting a mate's old Turkish pocket watch movement up and running again. I'm at the point where the movement is running well and keeping reasonable time, but I notice that the regulator seems to work in reverse. In other words, when you move the pointer towards "F" or "A" the balance wheel slows and when you move it to "S" or "R" it speeds up. Any explanation for this?
Thanks,
Rob
FNQ, Au
213042986_Turkbalance.thumb.jpg.b08e6f1c0b1abda5e9308beab560de97.jpgG'Day nickelsilver,
Thanks for replying to my question.
Both index regulator pins are present and the gap is small and pretty much spot on. When running, you can see the spring oscillating between the two pins (see attached photo).
G'Day clockboy,
Thanks for responding.
The end stud is tight and the the regulator adjustment arm is actually slightly offset compared to most other pocket watches I've seen (see attached photo).
I've placed the movement in its case and run it overnight. I notice now that what appeared to be a reverse in the regulator response might just be a case of the movement "settling in."
It's a very "low end" movement. The large jewels which appear in the first photos are just for "show." In reality there are no jeweled pivots in the whole movement. The big red rubies on the top- plate are some sort of end stones whose sole function was probably to fool the buyer. Even the balance wheel pivots are just metal on metal. I'm guessing the movement was manufactured in Istanbul, Turkey in the early 20th century. A fairly rugged, rough piece of work, but definitely not a precision instrument.
Thanks again,
Rob
FNQ,Au
You need both parts of the regulator and in line in order for it to work properly. The hairspring should be free inside the regulator pins and able to move freely no matter what position the regulator is at. This is not a compensated balance wheel so time keeping will not be spot on.
G'Day oldhippy,
The hairspring is free inside the regulator pins. I did close the gap slightly as it initially appeared too wide.
As can be seen by the last photo I posted, the the regulator was manufactured with the index pins offset from the indicator pointer. It is a bit of a "mongrel" of a movement, but it does seem to keep reasonable time... so far!  :)
Thanks,
Rob
FNQ,Au
G'Day nickelsilver,
No timing machine, just "eyeball and ear." I'm afraid my methods are almost as crude as the movement itself!  :)
The challenge was mainly just to get the old Turk running again and the accuracy somewhere in the ball park. The bloke that owns the watch has never seem the thing run at all.
Thanks again,
Buffo
FNQ, Au
7 minutes ago, Buffo said:
G'Day nickelsilver,
Thanks again,
Buffo
FNQ, Au
Ok, well, this thing could vary massively in rate over a period of hours and certainly over 24 hours. So it might be running a couple minutes/day fast fully wound and several minutes slow after 12-24 hours. Not figuring in how it behaves in different positions. So it is probably the case that the regulator is working correctly, but the watch is very unstable.
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
