Hey guys. I'm watch repair enthusiast. I'm now working on a vintage ETA 2762. I'm devastating because the calender intermediate wheel cant be set in the right place. It seems to be tucked in the cover plate but I can really tuck it in and meanwhile let the wheel runs freely. Please give me some advice and help! Thank you!
Remove the little cover plate, slot the coverplate into the groove in the wheel, install as one unit.
Anilv
Anilv
Thank you so much. I've done the assemble of the calender works. Very helpful tip.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
