Wolf Jahn Watchmakers Lathe
Right! That‘s not how the watch in question looks like though. Her is a video that doesn‘t show best practice but gives you an idea of the process:
By watchweasol · Posted
If you don’t want to buy a back removing tool there is always the glue trick.. superglue a large nut on the back when it sets use a Spanner /wrench to unscrew when the battery is in and the watch is working fill the nut with acetone ( nail varnish remover) , this will dissolve the glue, then clean up any residue. Job done. Use it regular and no scratches or marks. -
Welcome to the forum. My advice would be to start with something cheap and simple that has parts and service information readily available, unlike the Seiko Crown.
A snip from a google search and every one has a gold bezel. Edit If you look at this one on eBay, this is what it looks like without the bezel, which is clearly wrong. https://www.ebay.com/itm/276083094087
Thanks for the link. My movement is pretty much identical to the one in that post, without any of the markings though.
