Stem removal on a Swiss army watch
mark1
On 8/27/2019 at 9:55 PM, m1ks said:
At a guess, I'd say either press A or unscrew B and lift the brace, I'm sure that's what's locking it in.
 Well, It was sort of what you said, The post in the middle is what is actually holding the stem in. But the only way to get it to depress, is to move/remove the clip. Once I did that, I was able to depress the post in the middle, and the stem released. So, Now I've got the stem out, and trying to figure out which piece to buy to replace it. I noticed the numbers "1198" on the watch interior, And they seem to be numbers I see correlated to certain stems. Is that what I need? an 1198 stem? Here's an image to the stem I pulled out. Is there a name to this particular style of stem? Sorry for the newbie questions, I'm really good at due diligence and research, but this is like a stab in the dark finding info online for some reason.
Sorry I didn't reply earlier, have just checked back this morning on the forum.
I wouldn't have been much help unfortunately, stems are a pain unless a common model of watch or movement.
Hopefully that's the right one and glad you got it removed.
Thank you "Watchweasol" and "m1ks", I appreciate the help. Parts are ordered. Hopeful that I am going to be good with the crown I ordered, as the diameter of the original was 4.3mm and I couldn't find any that exact size, so I ordered a 4.5mm one. the space for it was 4.9mm so I think I'll be OK. I will update all this once the repair is done, in case anyone is ever searching for this info, like I was.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
