So I have a Seiko 7t92 watch with a stacked sub dial for counting hours and minutes. I need the hour counting hand but I can't seem to find these anywhere. There doesn't seem to be any place where I can find a small hand with a wide bore tube. Help?
I know the standard size is 0.20mm so what is the 'wide bore' tube size you're after? Cousins, and other sources, do sub dial hands at 0.26mm for instance but if you can confirm the tube size you're after there may be alternatives.
