Hi everyone I need help.
Recently I did overhaul on my Rolex 1570.
Assembled together and noticed when setting time the hour and minute hands are moving too loose and after push the crown back second hand moving but hour/ min hands not.
Did I use wrong lube on center wheel pinion, used hp1000
What I did wrong,
Thanks
Agree with @Nucejoe. There is a problem with the cannon pinion, but first try removing and cleaning--don't lube the center wheel pinion, and test the hour/minute setting mechanism. If there is still a problem, then you'll need to tighten the cannon pinion.
J
