i recently posted a query regarding a roamer with a 555.415 movement.i took it apart and i thing at least one of the train wheels looks a bit dodgy! this movement and the parts are now obsolete.will a 955.412 fit?the size seems the same,but the height is a little shorter ie. 2.50 as opposed to 2.75.many thanks B.
also could i use the stem from the 555.415 in the 955.412 as it needs to be a split stem?
As far as the winding stem, the Ranfft site shows them both as having the same stem :-
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA-ESA_955_412
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA-ESA_555_415
Not sure if the hight difference that you mention would be significant but I'd be inclined to give it a try.
Sent from my moto g(6) play using Tapatalk
thanks for that.it should fit then.needs to split stem as i have to go into case through the front.
