Seiko 7009 - escape wheel not engaged
Dear All
I have faced this issue many times and I really hope that someone could help me. Thanks.
During assembly of the 7009 movement, many times I will be stuck with the barrel and train wheel bridge step. The problem I faced is that it is very difficult to have the escape wheel and pinion in perfect alignment. In other words the escape wheel is not engaged when I turn the barrel. (Steps 49 - 38).
I hardly ever encountered such issue with the 6309 or 7S26, but with 7005 and 7009, I am always stuck with this step, that is getting the escape wheel to be engaged when I place the barrel and train wheel bridge over. Can anyone share some reason/s why this is the case?
This step usually takes a bit of time. I think that the escape wheel has a tendency to lean against the third wheel, so before I install the bridge I try to be sure that it rests on the fourth wheel instead, then I put the bridge as as softly as I can. Then it always needs to be adjusted with the tweezers until the upper pivot goes into its jewel.
Hi James   fitting train wheels and bridges is always a bit fiddley, assemble the train  lay on the bridge softly then fit a screw into the bridge to hold it, do not over tighten it , hopefully this will hold the train wheels while you manouvre  them in.  I made some tools from soft sewing needles bent at different angles to allow me to jiggle the train wheels in.
Thanks for your replies.
Turns out I've had quite a number of bad escape wheels - broken pivot at the top or bottom, that's why it does not stay in position and so there's no engagement. Could be due to over tightening from previous attempts or they were already broken when I bought them as used watches. I tried with a good wheel today and somewhat managed to get everything in place.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
