Dear All
I have faced this issue many times and I really hope that someone could help me. Thanks.
During assembly of the 7009 movement, many times I will be stuck with the barrel and train wheel bridge step. The problem I faced is that it is very difficult to have the escape wheel and pinion in perfect alignment. In other words the escape wheel is not engaged when I turn the barrel. (Steps 49 - 38).
I hardly ever encountered such issue with the 6309 or 7S26, but with 7005 and 7009, I am always stuck with this step, that is getting the escape wheel to be engaged when I place the barrel and train wheel bridge over. Can anyone share some reason/s why this is the case?
This step usually takes a bit of time. I think that the escape wheel has a tendency to lean against the third wheel, so before I install the bridge I try to be sure that it rests on the fourth wheel instead, then I put the bridge as as softly as I can. Then it always needs to be adjusted with the tweezers until the upper pivot goes into its jewel.
Hi James   fitting train wheels and bridges is always a bit fiddley, assemble the train  lay on the bridge softly then fit a screw into the bridge to hold it, do not over tighten it , hopefully this will hold the train wheels while you manouvre  them in.  I made some tools from soft sewing needles bent at different angles to allow me to jiggle the train wheels in.
Thanks for your replies.
Turns out I've had quite a number of bad escape wheels - broken pivot at the top or bottom, that's why it does not stay in position and so there's no engagement. Could be due to over tightening from previous attempts or they were already broken when I bought them as used watches. I tried with a good wheel today and somewhat managed to get everything in place.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
