Has anyone attempted a glass replacement on one the Diesel DZ 7071 watches? Is it even possible? I know this is probably not worth the time or cost but won’t know till I ask.
I have done some googling and found very little info on this watch,
Any help is appreciated.
cheers
Unless you'd get a donor watch I doubt that you'll find one.
By any chance, is it flat/straight and made out of acrylic ? If yes then you can make one on your own or have someone custom make it for you.
Hi Chopin    I too have a diesel watch DZ7070 and have trawled the net for tech info or any parts info and drew a blank on all ways,  so its confined to the to do box sometime. who ever made them for diesel again no information Its a mystery un less any on the site knows anything.
