Hi all,
I'm working on my quirky F300HZ Speedsonic with the 1255 tuning fork movement.
It had a dicky reset (too soft) so I decided to service it.
I have the chrono plate all together, it functions beautifully without the chronograph wheels.
When I fit the chronograph wheels with the little hearts it won't go back together.
I tried pushing the wheels with an oiler ( I have been able to align bridges with 7-10 wheels before no worries), no luck.
I have the chronograph in "running" mode when I re-assemble it so the hearts of the wheels can line up with the reset levers.
Anyone got any ideas??
The service manual is in German.
Anyone who's serviced one of these will know the trick.
Also I lost a foil washer that sits on top of both wheels - is this critical??????/
Cheers
I figured it out in the end. It required turning the runners until they fit in just right.
Weirdly When testing the movement, the chronograph reset was very hard and positive. As soon as I re-cased it all - it is back to a flimsy reset.
Anyone familiar with this movement??? I don't want to strip it down again - would have liked a solid reset, it just sort of plops in with a gentle touch.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
