I need to sharpen one of my screwdrivers for the first time.  I have a screwdriver sharpening guide on order but need to select a sharpening stone.  What do people use and recommend?  India or Arkansas stone?  Oil or water stone?  Fine, medium or co**BLEEP**?  Any guidance would be appreciated.
Cheers!
Roger
Hi Roger,
I normally use a diamond stone. I have both fine and co**BLEEP** so it depends, if it is not much I use the fine one. I found that DMT is very good and lasts a long time. Other brands are ok but some tend to loose their edge rather quickly. This solution could be more expensive but cheaper in the long run...and time saving.
Cheers,
Bob
I purchased this the other day just a thought? Does anyone else have any experience with these? I think they are 320 and 800 grit.
I use a softish Arkansas/Wichita. After sharpening screwdrivers, I use the fine side of one of those 3-way foam-backed nail buffs to take the crazy sharp edges off...don't know if it's right or wrong but they seem less likely to cause scratches
