Hi Folks,
I've just joined this forum and apologise in advance if this has been covered somewhere here already.  I did search and not find, so here goes.  In the attached photo, you can see one of my C652 type citizen watches.  It has multi-functions which are changed by turning the stem, this turns the small white hand in the dial above the 6 o'clock position of the hour hand.  The problem is, that the position of the hand 1) does not line up with its original positions around the dial i.e. 12, 3, 6, 9 etc and 2) it shows the "WRONG" mode.
In the picture you can see evidence of 1) in that the hand is between ALM-1 and ALM-2 positions (where as it originally stopped on the corresponding mark and showed alarm-1 or alarm-2 for example) and evidence of 2) while in this position it is actually showing the time!  The time however, should only be shown when this hand is in its respective 12 o'clock position!
The watch is not very old and started doing this maybe 1.5 years after I bought it (and no, no more warranty left on it).  The stem is difficult to turn compared to another C652 I have, although the watch functions otherwise how it should (holds charge, tells time, all functions work etc).
I wonder, is it really such a big task to go in and put the hand in the correct place and maybe clean/lube the stem?  Or would it be more complicated than that.  I don't want to sent to citizen because I am afraid they will just charge me for a whole new movement rather than use their brains and fix the small problem (well, I assume it is small).  I also don't mind paying a good watch maker to do it, but I wouldn't have a clue where that might be (I am "unfortunately" in northern Sweden at the moment and will be for a while).
Has anyone seen this effect before with citizen eco-drive watches?  Could it be it just needs a clean and "manual" reset of the indicator hand?  Granted it is a small problem, but it bothers the hell out of me and would love to get this back running the way it should!!  Any help would be appreciated!
Cheers,
Gordon
In reply to ro63rto,
I have tried the well known electronic "all-reset" (no video needed, there are instructions in the booklet that came with the watch) but that doesn't do anything to fix this problem, as it is mechanical I think.  I could also mention this watch has never been opened or tampered with. Just over time somehow the mode hand has shifted/jumped out of place, probably since new that stem was always stiff to turn.
Thanks anyway for the suggestion though!
Cheers,
Gordon
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
