I fit a jewel into a plate. It is a Seitz 30/200 (.3mm hole and 2mm diameter). The problem I have is that the jewel is too thick and I think touches the pinion on the third wheel where it’s installed. Is there a way of shaving material off a seitz jewel? Perhaps on a lathe with 2000 grit sandpaper or a burnishing file. Don’t know???? Help!
Turns out if you use a 2000 grit diamond plate, the one I use for sharpening gravers, and you hold the jewel with a short at toothpick that will not go through the hole, you can thin out the jewel.
I watched your video on this earlier today. Very informative. Thank you.
Thanks for the feedback. Really appreciated
there is a fair bit on content in George Daniels book on making jewels, everything is done with diamond.  good on you for solving the problem
Thanks...watch repair IS problem solving
Sent from my GT-N5110 using Tapatalk
What is the name of this book you talk of.
