Hello mates!
This weekend I'm struggling with this bumper moment. But is not going steady, but stops and go.... So I found out that the balance wheel is touching the third wheel. This is a new issue for me...
See photo, the red ring is where the intervention is ..
Wounder where to start?  Doing what?
Tolerances shouldn't be that tight between centre wheel and balance: https://www.youtube.com/watch?v=_BxvHLW2evM !  ;)
I'd start with the centre wheel and check there's no damage to the pinion and that the wheel itself sits squarely i.e. does not have a small deformity in it which means it does not then run truly horizontally. After this check that the wheel can be seated cleanly as per https://watchguy.co.uk/cgi-bin/media?image=IMG_9744.JPG&email=&wat_id=680 (click on the image to get a close-up). Since you will have had to remove pallet fork and balance to do this it's worth double checking a true running by looking at the centre wheel while the train rotates and that everything looks okay.
If that all checks out then ensure there is no foreign object that has somehow gotten under the balance cock and that the balance can subsequently be seated properly with the balance cock fully screwed down.
Any joy?
Photo is blurry. The outer most HS strand appears to have run over the regulator arm.
Clear pic please.
Wobling third wheel is fixable rather easily. The case of wobling BW is a bit more invloved. Will go step by step and carefully.
Staff and arbor end shakes, if too much.
Hello thanks to both Watchmaker and Nucejoe!!
I will try to check the issues you pointed out Watcmaker. And to you Nucejoe, its just an illusion the outer most HS strand have not run over the regulator arm. I will check out the third wheel first...  Good Sunday to ya all  !!
" Stops and go"   Just a reminder, Wobble of the BW when runing is obseravble from side view. If it wobbles and you have no access to truing caliper I can  post pix showing how to level the BW inside the movement.
If the ballance is hurt, Omega poise is lost.
Third wheel is no big deal. Should just exercise caution not to hurt a tooth or knock the wheel loose on arbor.
  • 4 weeks later...
Last update her mates!!
Got it up and running, but I need to adjust the BE, and this balance wheel have this screws to adjust. And I have never done this before..
Is it somebody that explain, if I adjust the speed first and the the BE, or the BE and the the speed, or both and the same time??
And how to operate witch screw first, and what order?
I would correct the beat error first. Mark shows this here (4:00):
Watchmakers often mark the correct position. So here I would try and turn the collet a bit anti clockwise until the stud lines up with the mark on the ring and then do another check on the timegrapher.
So the screws have nothing todo with regulating the BE?  And that only have to do when they made the wheel aligned?
Okay, then I have done the adjust of BE by moving the balance wheel befor, so thanks for great help.
    • I was wondering because of the alum idea.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
