Hi
Does anyone know if there are any videos of how a chronograph mechanism works or even a simple day/date mechanism?
I know about the cam, etc but it would be nice to see it working in a video; these things aren't always visible in a watch.
There are some good videos of escape mechanisms; it would be nice if there were videos of the above.
Thank you,
Dave
