So got a doner watch and thought it looked good  took the back off and thought let's put it through its paces on the time grapher ho dear ..... _ 432 s/d amplitude 0.3.   lift angle  @ 52  @180 degree  then 90 degrees 644 _ s/d amplitude 3.4ms ect. So strip down commences visor on can you hear me major Tom ?    Yes Ferric oxide don't know if one is allowed to say rust .now ........the problem that really caught me out as a newbie was SCREWDRIVER slip and thought it's the blade thickness that was not fat enough and sure enough it wAs  so for all newbies it's just not the width
People have different ideas on what's the best for them, brand and design-wise, but I have found that my Bergeon screwdrivers have been great over the years. I very rarely have problems staying on/in the screw slot with them. I will admit that I usually buy new tips instead of sharpening the old ones. One day I'll buy the right sharpening jig and that will probably change. Good luck.
