I'm having difficulty removing the case back on a Seiko 5ACTUS.
There are no slots to give a blade a start.
I've tried finest blade I have ( but not a razor blade ) and no amount of pressure will allow me to start it lifting.
This is the first time I have been defeated by a case back.
Am I missing something?
HELP PLEASE !!!!
