Hi, can anyone tell me how to release the winding stem and button on this watch please.
Omega Electronic f300Hz DEVILLE CHRONOMETER
I have tried loosening the ss screw just above the rh coil but this has no effect. Also it looks the same as several others so I don't think that is the one.
Other watches seem to have a sort of dimple to press but there is nothing like that on this movement.
Am I missing something obvious?
Also is there any way without stripping the movement that I can remove the light staining on it. Just to make it look better.
Edited by Alaskamick
Forgot to ask another question
Hi,
first of all - attention, this is not your average movement. You can make serious damage to the watch if you don't follow strict disassembly.
RAY11579.JPG.c4a8f2ee84908851f919f3a64be49f35.thumb.png.c2a7e2bd11dfa620ab34e4e83c835a5d.png
The red arrow indicated the dimple you have to press to release the stem. The Green lines show the screws you have to remove to be able to remove the oscillator module. DONT remove anything from the case without first remove this module.
I you cannot simply rub away the oxidation as it is on the oscillator module as there is a very sensitive 300 teeth 2.6mm wheel called the index wheel in this module and some tiny tiny fingers.  There is a bad scan out there of the movement maintenance manual (ESA9162) (just google for it).
If you have no clue, I would not go to far otherwise I bet you will damage it. If the watch runs, take immense care that you do not damage the coils. They are nearly impossible to get these days. I started restoring tuning fork watches of this calibre and it is not simple if you dont got a basic electronic understanding and a 30-40x microscope.
If it runs, close it. If its not. Look for a replacement movement. It does not have to be omega, it could be any other ESA9162 or ESA9164 if it has a date.
If you want to get rid of it, let me know I collect parts to repair some.
Greetings
Max
Hello Max, you have answered my question. I thought that ( only using my specs ) the dimple you mentioned was a tiny cross head screw but as you said it releases the stem.
I have no intention of working on this watch as it is running and keeping perfect time and anyway I know that it is beyond my capability to do so.
I have had it for a while but someone, not me has fitted a new stem and not got the length correct so there is a gap or not tightened enough as the button unscrews when i reverse wind it so I just want to attend to that.
I asked about cleaning the back of the movement as it is a bit stained. I wondered if anyone knew what to use with a cotton bud just to make it look better. Obviously I would keep well away from the mechanism, just gently clean the flat plate keeping the bud almost dry.
Any way thanks for helping me, I will fix the stem so that it is correctly fitted  and then sell it.
I have realised that the electronic Omegas and Accutrons which I have need to be got rid of before they get problems which I can't repair myself and I end up with watches that have to be sold for parts.
Thanks again and all the best, Mike
On 2/4/2019 at 4:36 AM, Kamran said:
I have those movements two pieces if you need them let me know
Hi, this is not even a similar technology. We are talking about a tuning fork watch and your offering a quarz movement.
Hello Texas Don, yes I did manage to refit it after I was advised as to how to remove it.
I got it out, shortened it and tightened the crown, refitted it and now it's perfect.
Job well done.
Thanks for your interest, All the best, Mike
  • 1 year later...
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
