Hi All
Hoping to continue my learning from last winter (when work slows enough to allow the hobby) I'm attempting a dis/reassembly of what looks to be an AS 1700 in a Sears Tradition.
On the top of the rotor is a bracket (4th and 5th pic) which is held in by one screw with threads.  The other screw (shown) has no threads and just floats under the bracket (see red arrow) is far as I can tell. Removing this bracket appears to have no effect on the rotor.  What is this thing for (floating screw and bracket)?  Notice that bracket has arrows on it.  Why?
Thank you for any help
Charlie
Maryland
That's it!  Thank you, RAG.  It's interesting that Cousins have these work sheets available.  Are more available elsewhere?  I could use one for a UTC 233?
Sadly I am not aware of any, especially for vintage movements. But you could always take pictures and notes of every single step during the disassembly process.
Hi @Lc130 - it's always worth looking around the background of a movement and/or the family it comes from.
In this case the history behind Universal Time Corporation (UTC) is that it was set-up by Seiko in order to sell unbranded versions of their movements to manufacturers to build their own watches from.
Ranfft tells us that a UTC 33 = Seiko 6601B so you can instead search around the latter and its family e.g. 6601A ... https://www.cousinsuk.com/PDF/categories/2862_Seiko 2451,6601A.pdf ; 6602B ... https://www.seikoserviceusa.com/uploads/datasheets/6602B.pdf etc. You get the idea!  Good luck! :)
Thank you WatchMaker!  I didn't think of that.  Very helpful and a new bit of knowledge for me.  I do take lots of pictures but every little bit helps.
Its a simple way to remove the rotor. Just loosen the screw (the one which does not have the two dimples next to it) and swivel the locking cam. The rotor will lift straight out. It needs to be lifted straight otherwise it will 'jam' , I find that rodico helps. Or you can turn it dial up and tap the case and it should fall downwards.
Anilv
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
