Hi , Connection problem, so preveois post was short.
If you are talking of excessive friction between canon pinion and it's  driver wheel, normally no more than  oiling ( tiniest bit)  should do, however, if the tube section of canon pinion is sqeezed /damaged so much to make contact/friction  from inside of the tube, I would vote for replacement. Plenty of eta 2836 parts on various sites.
Regards joe
The tube of the pinion isn’t damaged but it seems to be excessively tight where it is attached to the driver wheel. It is so tight that the minute wheel will pop off if I attempt to use the setting wheel.
I will take the whole assemble off and see what I can see when I get the time.
Thank you for your considered input. It is appreciated.
Hi Joe
I always put it securely in place. I think it's excessive friction on the cannon pinion. I'll take it apart and see what I what more I can do; I've tried oiling it with 9020 and it didn't really help.
I'll let you know how it goes.
Dave
I wonder if there is maybe a build up of oil oil or corrosion in there. You could try polishing it with an abrasive like autosol or brasso and then thoroughly cleaning before lubricating again. Or just buy a new part for £5.
Hi Joe
I took it out and it was full of crap. I cleaned it and put some grease on it and it eased it a lot. I am cleaning it again and I will grease it again and put it back and see how it goes but it turns MUCH more easily now than it did before.
It took a x15 loupe to see all the filth!
Dave
Hi,     The center tube is removable to brush, also a piece of thread run through the tube works to clean it,s inside.
How about the rest of the minute train? All its parts can be brushed in cleaning fluid.
Regards joe
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
