Black slate clock.
antonyh
I know it's not slate or marble,  but every will know the sort of clock I'm referring to , anyway.
I brought one at a car boot sale, just can't  resist  a broken clock with bits missing, the fact is you always  learn something along the way.
So it's was missing a hand , not a problem,  pendulum,  not too much of a problem with  the fact is you can just pick up a catalogue now days.
And the fine regulator for the pendulum, , well I now now the diffence between the brocot and the vattet suspension system.
So after much searching through my boxes of stuff , I found one and with a little work ,, it's now as it should.
I will get round to posting a picture of the case, but as with a lot of these clocks the cases get damaged easily. .
In the meantime I'm  sure there's a few of you  that will share your pictures.
If the case is heavy, it will be slate. I say this because some cases are painted black and they can be wood. The movement is French, most have numbers on the back plate and sometimes one of the numbers will give you the length for the pendulum. This site will help you with the pendulum.
http://www.m-p.co.uk/formulae/frpend.htm
Just a quick add on for those who are interested in the black slate clocks.
I kept looking at my clock top and back of the clock case, all white in places,  the top was awful where people had put things on, cleaned it with various cleaners,  so it was pretty bad.
So I thought I'd try some of tha Curator, not used it before,  OMG what a transformation.
So easy to use as it's water based, use gloves when your using it.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
