Hi all
I am looking for a tech sheet/oiling guide for the early (1960s) Omega Cal. 611 or any of the 6 series will be helpful - can you help?
I think that even the 55x/56x might even do.
Hope you can help
Cheers
John
Found this for lubing a cal1154.  Probably using the oils shown in similar positions on an older watch would be OK.  I used these for a Cal-552 I did a year or so ago and it still going great. I used  Moebius HP1500 to replace D5.
Omega 1154.pdf
    • Would be worth starting here Del, if they don’t have it they might know someone  https://www.barometerworld.co.uk   Tom
    • What size hands do you need as most wholesalers have a selection. Agian most wholesalers have a selection of crystals depending on the shape. No would be the answer to UV glue as it doesn't work in a sandwich and only the overspill exposed to UV sets.
    • To start searching for hands, measure the diameter of the hour wheel where the hour hand attaches, and the tip of the cannon pinion where the minute hand attaches. Use calipers that are accurate to 0.01mm, and then you can look around ebay for hands about the right size. It is typical to have to either close down (concave punch) or broach open the pipe when fitting hands since you won't usually find a set that is the exact diameter of your hour wheel & cannon pinion. It is reasonable to work with something about +/- 0.03mm  Measure the thickness of the 4th wheel extended pivot for a seconds hand. Cousins does sell some new hands for pocket watches, but I don't find them suitable for old watches. They just don't look right so instead I managed to win an auction on an enormous assortment of old hands. It's sort of fun to pick through them and measure to find a workable pair. I use this tool to measure hands:
    • First thought was Ali but not quite the right size. https://www.aliexpress.com/item/4001332181418.html?src=google&pdp_npi=4%40dis!GBP!15.89!15.89!!!!!%40!10000015722336818!ppc!!!&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&gclsrc=aw.ds&&albagn=888888&&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=en4001332181418&ds_e_product_merchant_id=109329972&ds_e_product_country=GB&ds_e_product_language=en&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=17859500389&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gad_campaignid=17190468917&gbraid=0AAAAADznYb9wcm3yr5TVnjKS13BUaCYRa&gclid=Cj0KCQjwoZbBBhDCARIsAOqMEZX56VaN03sqlHk3bDswNOyXmi-lHQRBwgyt3mVympigQhcfH6Iqb94aAnEsEALw_wcB
    • I'm looking for hands (3) & a crystal (4cm dia.) for my watch Serial No. 85590 as shown in the photo. I'd be grateful for suggestions re potential sources; and to know if uv glue would be suitable for re-fixing the 12mm dia. seconds dial.
