I purchased a Timegrapher 1000 from Ebay, Tangtangme was the seller. When it arrived I didn't have the time to check it as I was going abroad. When I returned some weeks later I decided to check a watch I had rebuilt using my new Timegrapher. I plugged in the microphone then plugged in the power supply and switched on and nothing! I contacted the seller and they did respond with "Tell us when you bought the item". I did and I have heard nothing since. I have tried to contact them many times and have received no response. I decided to have a go and see if I could determine why it was not working. What I found was the power supply DC output was reversed so the middle pin was negative  and the outer was positive. I reversed them and tried a power up. Hey presto she lit up and came on. The microphone was dead though. I opened up the timegrapher and discovered the reverse voltage had blown the 5volt dc to dc converter chip. I got one and replaced it and now I have a fully working timegrapher. Why am I sharing this? Just in case you get one from the same place I did. If you did and you need help to fix it just let me know.
I am looking for a Platax tool if anyone is selling one please let me know.
Thanks for that colditz  its a case on caveat emptor( buyer beware)  I use a Horotec unit, Often thought about The Timegrapher. If I go down that route I will look for an English supplier, although its not to say the result would be any better
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
