When stuck with an Impossible to find antique balance wheel, you wounder if you can bring the wheel back to shape. Are there any tools? Techniques? Or just Ebay technology?
Regqrds joe
Thank you Sir,
I see, the tools " truing calipers " shown by the link, are versatile for the task.
Just seeing the picture is good for a start.
Regards joe
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
