Gant West Creek W10373 weekday problem
Ephex
Hey.
I recently bought a used watch whose batteries needed to be swapped. Today, I went to a watch shop and they fixed it for me, but they also noticed that it couldn't show the day of the week. The indicator is stuck outside of any days:
Screenshot_20181023-154717__01.thumb.jpg.7f06b19a5d9cc73bb73e49e5f137ed88.jpgScreenshot_20181023-155433__01.thumb.jpg.e8ec07b3a757f30f30e32ae2fe3d95e2.jpgScreenshot_20181023-155426__01.jpg.64edc669aa143ff46b78c7fc262b8eef.jpg
The leftmost picture is from me, while the other two were from the seller.
Is there any way to fix this? Any help is appreciated.
//Ephex
Odds are good that the hand for the DoW indicator has come off the pinion, or at least become loose. If you were to remove the hand entirely and replace it, through some trial and error of resetting the date you could probably find how it should be oriented. Ideally when testing, put it back loosely so that it stands proud enough to not get fouled on the dial.
It is also possible that the day needs to be rest after the watch battery was replaced.
You would need the calibre number of the movement to look that up though, but most likely as qhartman says the hand has just come loose and needs to be refitted, but that will require the movement to be removed from the watch
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
