This is probably a premature question but I'm about to attempt a cleaning of a Bulova 11BLC movement.  I noticed an extra gear on top of the plate so I guessed it was to run a seconds hand.  The best I could find on the internet was an arrangement called an indirect center seconds movement.  The watch does have a spring above the center wheel like the movements I saw online however it has no seconds hand at all.  I'm guessing they didn't use this arrangement to employ a seconds hand on this watch but all the stuff is still there.  Any pitfalls to working on this type of movement?  I read that this extra gear is attached to the third wheel.  Thanks!  Dan.
The spring would have held the centre seconds hand pinion in place, it is doubtful that they would have used this movement on a watch that had no seconds hand and left the pinion and drive wheel on the third wheel pinion, are you sure that the centre seconds hand is not missing ? pictures would help if you can supply them.
You should be able to find a seconds hand via Ebay or a parts suppliers, the only other thing to say when servicing these watches is that the drive wheel for the seconds hand sit on a extra long pinion on the third wheel it must be removed with care and needs to be pulled straight upwards a presto hand removal tool can be used for this I always replace them using a staking set other than that it should be straight forward to service this movement.
Here is the picture, sorry it took so long.  I checked and it does have a pinion for a second hand!  When you say get one from ebay or a supplier, what specs do I use?  I tried measuring the pinion with a Seitz jewel gauge but that didn't work.  I can try a micrometer but there is very little sticking up.
When you say remove the top wheel from the third wheel with a presto hand remover do I assume you do this before you take the plate off?  And when you say to use a staking set to put it back on do you mean to put the entire watch on the anvil and press on the wheel?  Again, I want to make sure we are talking about the large wheel above the third wheel.
I did see the post you mentioned but couldn't make heads or tails out of it.  Perhaps it will become clear when I take the watch apart.  Anyhow, many thanks, I have learned a lot!
You can check the watch hand sizes by using a sight called Ranfft :
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Bulova_11BLC
In your case the pinion is 0.18mm for the seconds hand.
Yes
yes with movement held in movement holder there is enough clearance on my staking set
Yes
23 minutes ago, Nucejoe said:
Glad center second hand pinion is found undamaged.
My question is:
Do we oil the hand and keeper joint?
What is a keeper joint?  Also, would you put a bit of grease on the little gear at the base of the seconds pinion?
by keeper joint I assume you mean the friction spring and end of centre seconds pinion ? if so a tiny drop of 9010 can be used the springs job is to provide just enough friction on the pinion to stop the second hand moving in a jittery fashion when the watch is running.
No not needed
Thanks everyone for all the help.  I got the movement back together today and it runs great.  I re plated the case and polished the scratches out of the crystal so it should look good.  I will have to wait to case it because I just ordered a seconds hand from Ofrei and that will take a few days to get here.  I might have to ask for advise on inserting the stem but I'll play around with it first before I install the dial to see if I can get it to work.  Learned a lot on this one.
    • I was wondering because of the alum idea.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
