Help with the old clock
I set apart this old clock, cleaned it, and now I want to oil it and put it back. Using the photos I made during the disassembly, I reassembled it just to the end. Now I have problem with these two giant springs on the right side. Either they wont get in place, or they just jump out suddenly. Any idea how to put all this back? Thanks.
https://imgur.com/a/KdUUxBa
If the movement is back together and screwed/pinned. You need to make sure the spring is hooked on the arbor then wind it up, when it is nearly fully wound you need to feed the end of the spring over the pillar, which will hold it in place. Repeat with the other. So the spring catches the arbor you might need to pull on the spring part way in so as to take up the slack and the end is tight on the arbor.
Let me know how you are getting on.
The problem is actually how to wind up the springs, in order to put them in the cage. Once they are wind up, it is easy to hook them on arbors (in this case they are the upper supports of the whole clock cage). But they always jump out, and I also have other wheels to put in (at least four of them). I already decided to put the balance wheel last.
At the beginning of the process, the springs are unwound and take a lot of space. It is hard for me to wind them enough so they can be placed in the cage (since the springs are attached to the upper bridge so to say). So, I need to wind them enough to put them both in the cage, and then hooks the end on the arbors. Then they are under tension and that is it. However, once I try to wind the spring, and put them on top of the movement, they jump out.
  • 4 months later...
Hello again,
I have finally time to get back to this old clock (Viktoria 7 jewels). Still, I have no idea where to start and I expected it would be a lot easier (I mainly worked on watches and this thing is huge). I did found the photos I took during the disassembly but they are not of much help (here: https://imgur.com/a/subHhf1)
Did anybody recall any similar clock mechanism whose drawings I could use to put this clock back?
The most difficult part are still the huge springs (especially two of them which are kinda connected). I didn't find a way to put them together them in cage (they always fly get out somehow). Other parts are mostly in good shape and with a proper lubrication should be fine.
Edited by bojan1990
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
    • can I ask why you're not happy? did you notice that the acceptable low 24 hour amplitude of this watch is 160°? is there any possibility that a watch company could manufacture a watch that could actually run at a low amplitude and keep time? so if they can run at 160° at 24 hours and keep time then they probably would keep time at 240° which yours seems to be doing? then if you're really unhappy with this I would recommend purchasing an original Omega mainspring. Just because the aftermarket have numbers like an Omega mainspring it doesn't mean it's the same thing. Then I would also recommend replacing the escape wheel and the pallet fork. This is what they do in the Swatch group service center if they are unhappy with anything on the other hand they have an infinite supply of spare parts.
    • That was reason for asking for mark's input, i wasn't sure if going ahead with dealing with the contact information would be particularly well received. @oldhippy thoughts ?
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
