Tool for removig oscillating weight on Sellita 300.
If you use your brass tweezers to hold the escape wheel by the pinion, can you turn the wheel with your fingers? -
Of a pivot is broken and they are not engaging. -
That means that the escape wheel's abor is loose. The wheel remains stationary while the pinion is spinning. -
I decided to give it a go. With the hope I can replace the missing pieces. Fingers crossed 🤞
