Porcelain Clock
Murt
porcelain clock 1890 clock
I'm looking at this beautiful porcelain clock of a kingfisher bird painted on the clock.
Its up for sale on my local adverts for 160 euro. Could anyone be able to tell me anything about the clock and its value. Thanks
That is a French timepiece and they are normally 8 day duration. The hands are a style called fleur de lis. The dial looks to be porcelain. On the back of the clock movement there is a number. If the pendulum is the original, it will also have the same number on it. The movement is in need of restoring. It is made of brass and should be polished.
Thanks very much oldhippy. I plan on keeping it for myself. I do a bit of wildlife and landscape photography at the weekends and my favourite bird is actually the Common kingfisher(Alcido Atthis). Thanks again for your input.
You are truly amazing with all your knowledge of timepieces.
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
