My father was a royal navy pilot and when he passed I received his old beat up lemania monopusher service watch.
It is missing a stem and crown for sure, but I am hoping that the movement itself is still in workable condition and would like to try and get it repaired if at all possible. There are no decent people in my area who I would trust with it and was hoping to get some recommendations on who might be experienced and qualified to work on this time piece.
Any suggestions greatly appreciated!
Couple of photos below.
Thanks!
https://photos.app.goo.gl/Ak2VUdrv3GnVspti1
https://photos.app.goo.gl/rKERNk0YnHg9w8Vr2
Hi,
That’s a very valuable watch. I may have a spare crown, but would take me a little while to locate it. Cousins may have spare stems.
If you plan to wear daily then I would recommend getting it serviced. If not, then replacing the stem and crown may have it running reasonably well for the odd occasion.
Roddy
30 minutes ago, rodabod said:
Hi,
Roddy
Roddy thanks for the advice
If you can source a replacement crown and stem I would certainly be interested in buying them.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
