Pallet fork arbor change.
The spring keeps the threads of the crown and crown tube separated while you are winding the watch. It will work without, but the risk of the thread engaging, or worse, cross-threading, is high. The split stem needs to give the crown enough end float to disengage from the thread, but leave the main part of the stem and the keyless works in the winding position.
By Michalzeszen · Posted
I see. And is there a possibility to convert it to a springless system by replacing it with a standard split stem model? -
Sharpening gauge. I found the easiest side to do was the safety roller as the roller table laid flat on a block provided stability. The other way requires a specific stump for the roller and pin to sit in, but may also grip better way.
