Elgin 6S PW, escapement woes
Is this person still around to answer questions? It would be interesting to know what they put into the barrel. Has the watch been worn regularly in the last 20 years?
I am planning on making some homemade Etachron tools from brass rod. This will be flattened and formed into a a flat crescent, with a slot filed into it that will act as a wrench for turning studs. Would steel be better? I could use pieces of old mainspring that I have annealed to allow them to be filed to shape. Does anyone know the dimensions of the studs? Are they all the same? I know that there are differences between Seiko and ETA. I only have one watch on hand with Etachron (an ETA based movement), I can measure this but I don't know if that would do for all ETA based Etachron.
I made some similar probes out of 3mm brass rod. Chucked short sections in an electric drill and did rough shaping against a file. Followed by an oil stone and them progressively finer emory cloth. Very useful tool for shock springs.
One available here, not too badly priced either https://www.ebay.com.au/itm/126925987414 Edit# sorry I see later that you have already this one in mind
