Seiko 7S26 Mainspring
Don
For those of you who are servicing Seiko 7s26 movements, are you removing and cleaning the mainspring? I've read that the Seiko barrels are difficult to open and maybe not meant to be opened. However, the mainspring and barrel complete seems to be discontinued.
Its a bit tricky to open but it really should be so that the mainspring can be removed, cleaned and lubricated. The barrel lid is not flat but has a side which is a bit different from regular barrel lids. And the lip of the lid goes right down to the barrel teeth.
The lid does come off like any other barrel but because the lip it is quite easy to damage it or the barrel teeth. I usually use a fine stanley knife blade to gently prise it away - the blade should be super sharp in order to get in between the lid and barrel. Slide the blade along the teeth inwards and apply a bit of pressure being careful not to twist the blade. And once you see a gap appearing then very carefully twist the blade, being cautious not to damage the soft metal of the lid or barrel teeth.
The mainspring is also left handed on these movements.
Hope this helps.
    • I'm guessing, but this commercial demag machine maybe produces random magnetic fields to re-randomise  the iron particles. So heres one for you, synthetic rubies are coloured predominantly with chromium oxide . But natural rubies and old synthetic watch rubies were also coloured with iron oxide in higher percentages than chromium oxide. Which gave them a degree of.................🤔
    • I've never had a hairspring distort on me by passing the movement or just the balance in a plastic pot over this demagnetiser. Have you seen how fast a cleaning machine spins to spin-off fluid and that does no harm to a hairspring. I was a little concerned when I first used it, thinking it might be too strong, but I was wrong. It is strong, but it does no damage. I pass the part over the demagnetiser and keep going for about an arms length, so about a metre, to properly demag the part.
    • I don't think you would be able to find spare parts. Your best bet would be to get a new movement from eBay. https://www.ebay.com/itm/256508500506?itmmeta=01HY3M863PSA61GK7B859QCWTE&hash=item3bb9191a1a:g:ubgAAOSwrJJgPP-s&itmprp=enc%3AAQAJAAAA4DxWhpiQiz2ZjKpm3PS%2FHPh4IafsSzMWEobc2q4qQWgPGMZ8kCR8y2PRsm7GE31FjeSDYSWcEyGlrpZEdQyyzOSgsgsaPjbP7dYmK8r49Nh%2BEtSqDDIZ8Tbp3vvX035fFXgcjc1GEH8l%2FOWJ9aTeWNGzeBgUwqyhJ3ZSXji50TQr6rd38Sqwaqsj2oc51UVKqqIKySKTfxVB7X09EXcJsmeYc5GCdVODNkb02q2RsxfSIzpgl9dFCmW1Ih%2BPg2j2NziSELg5AfaHl%2FPU2Zn9fNnoVN1Z1NUAREyh2BCubcWC|tkp%3ABk9SR_bhoPTwYw
    • Here's a thought. Try unscrewing the bezel and the crystal. If you have one of those sticky balls for undoing casebacks, I would give that a try.
    • Last week I noticed my Eco-drive's second hand was stopped at 12 o'clock. I left it in the sun for a few days and no change, so I figured it was time to replace the rechargeable battery. I've had this guy for at least 15 years. Replaced the battery and the seconds hand moved to about 5 o'clock and stopped there. I let it sit for a day in the sun, no change. I took the battery out and tested it, and it's at 1.4v. The old one was at 1.0v. I'd like to test if it's charging. I've been looking around for diagnostic info, but only been able to find the owner's manual. Anyone have a reference for it?
