Skagen Hagen SKW 6217 BATTERY CHANGE
I own a Skagen Hagen SKW6217 watch.
The battery just died in it.
I can't seem to figure out how to replace it. Read online about it's top load design and unit body form.
All I see is a screw at the back of the watch.
All the jewellers I have taken it to are unable to replace the battery cos they can't seem to open it. Is there anyone who can help guide me on how to open it?
Some models of Skagen are sneaky, i did a little bit of googling for this model but could not find it. I was considering that it might even be solar powered, i've come across two skagens that were solar powered but did not state anywhere on the outside of the watch that it was, and they both had that line on the back with the model name in the lower right hand of the line.
Honestly if you can't find a watch specialist who's competent to do this I strongly suggest returning to manufacturer.
http://www.skagen.com/us/en/service-information.html
However, I will say that it is very likely that the crosshead screw on the back comes off to expose 'the setting lever' which can be pressed to release the winder and from there once you have the front off it should be possible to drop it out.
oh, i just found it actually, okay looks to be regular quartz, not solar. and the front should be removable by prying off, it's also a little less expensive than i assumed so I could understand some reluctance in going through a Skagen workshop, however, I will re emphasize this could go horribly wrong for you without the right experience and tools.
6 minutes ago, Ishima said:
oh, i just found it actually, okay looks to be regular quartz, not solar. and the front should be removable by prying off.
Correct. I did not check, seems like the bezel is removable, no pump needed. I agree with Ishima, do not try DYI that, too easy to scratch or otherwise ruin it.
skagen-hagen-black-dial-black-leather-me
This is enlightening!
Prying off the face would need something different from the regular prying knife in watch repair sets, right?
You need a sharp blade, which is kind of dangerous. Bring it to a watch repairer, not a jeweller.
Had really nasty experiences with watch repairers. That's why I picked up watch repairs as a hobby and to try something new for myself. We learn everyday.
Will look for a sharp blade for it then.
But there is no bezel. Do I just pry at any point after taking out the crown?
Just a day on this forum and I made huge success. I was able to open the watch (there was actually a bezel at the top but hard to see) swapped the battery (621SW).
Had a tough time closing it back since I don't have a watch press. But I padded the nose of my pliers and applied gentle force till the front snapped shut.
Watch is working great now.
Thank you @jdm and @Ishima
  • 4 weeks later...
Hi, I have the cousin to your watch (the SKW6216). Removed the screw, took off the crown.  I've managed to pop out the glass like the video instructed, with the pump method but the bezel was in the way of the everything else. Where was this bezel at the top you found? I feel so close yet so far from replacing this damn battery. :wacko:
Look closely at the attached photo. Hope you can see what I am referring to.
  • 1 year later...
Hey! Did you need to remove the stem before taking the front off? I was struggling to get the stem out!
To remove the mov't you have to remove the stem first.This is true virtually for any watch.
  • 2 months later...
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
