I'm just learning the very basics at this point.  I've picked up an Elgin grade 345, 12s PW on ebay.   Here's more info: https://pocketwatchdatabase.com/search/result/elgin/20602697/movement.
I was able to disassemble, clean in naptha with an alchohol rinse and reassemble.  I didn't oil it as I'm just starting out and just recently ordered oil.
Before the clean, it would only run for less than 10 seconds.  Seems to run happily now until I turn it upside down and it stops.  I noticed that the third wheel upper jewel is cracked.  I didn't remove the screwed in jewels for cleaning.  Should I have?  I just cleaned them whilst in the plate.
Is this a balance problem?  I didn't take the balance assembly apart as I suspect, it this novice level,  I'd ruin it.  Does anyone have troubleshooting advice?  A pic is attached.
I appreciate your experience!
Charlie
Hi Lc130,
It is hard to tell from just the one picture but It looks like you most likely have a broken balance staff. I would suggest checking that there is not any movement vertically and horizontally of the balance. The cracked jewel could also be a big factor that could stop the watch as it could cause the wheel tooth engagement to not be correct. I suggest taking the balance out and being extremely mindful of the very delicate pivots while doing so. Check that they are not bent, mushroomed, or broken off completely!
Good luck! Let me know if you have any more questions, I would be happy to help. And don't forget that stuff gets broken along the way. Good thing this isn't a hugely valuable or rare piece!
Cheers,
-Emil
The cracked jewel should be replaced anyway even if it is not the fault. Normally when you have a large positional error/fault the hairspring and balance areas are where to look.
There doesn't appear to be any excessive play in the balance.  Below is a not-too-clear pic of one end of the staff.  I can't get a pic of the other end without disassembly but it looks the same.
It appears that if I loosen that microscopic screw highlighted at the top, that the wedge directly below will come out.  The wedge looks to hold the the other end of the spring.  Does this seem correct.  I could then get a better look at it.
How does one get a new staff or jewels for this?
Many thanks!
Charlie
Yes thats how the hairspring stud is removed once the regulator boot has been turned as well. Looking at your pics the top jewel looks very dirty, has it been cleaned. With a lot of vintage watches that have not been serviced the jewels get incrusted with old oil/dust etc. and they need a good soak in a de-greaser then cleaning. If the jewel is clean and the balance is good with no end shake then check for end shake of the wheels & barrel assembly.
    • I am sure you agree that,    " physical reality is actually made up of structured information "  which defines the states energy may  realize in prescribed  states.      Universe is committing suicide then most of its functions stops, but what we know as  gravitation remains, thus ( as he concludes)  gravitation proves of no essence  for actualization  previous functions universe used to work according to.   No doubt mathamtic systems man has deviced  is basic and not neccessarilty correct . But if universe is informational,  its also computational.   Then we have something thats has no essence and computation systems indicates it as virtual.
    • Oh that is lovely, thank you. I also just cracked the crystal and lost one of the shock absorbers, so its gone in the separate baggy of 'maybe-one-day' 😄 I did learn the valuable lesson of not disassembling the shock absorbers. My next one is a Zaria 1509B. I think this one I'll take a bit more time with cause I'll need to source a couple of bits. It's also scary teeny.
    • More data on the oscillation tests: Vertical: 15-20 seconds…Abysmal Dial up: 1 min 15-30 seconds Any thoughts @nevenbekriev @JohnR725? My next thought is to oil the balance jewels to see if that helps. It’s certainly one major thing left that I haven’t done.
    • Hi. Once the pins have been withdrawn the brace let comes apart, never had a problem with these.
    • Hello and welcome to the forum added the racketa 2603 sheet incase you don’t have it. 4328_Raketa 2603.pdf
